In addition to being budget-friendly, today’s laser printer is more compact and easier to use than older models. You can also find these
printers at a variety of price points, with both affordable and higher-end options available to meet any workflow.
That’s a definite positive for professionals who work from home because laser printing is still one of the best ways to expand the scale of your projects. Of course, you’re also looking to increase your output without losing space, time, or too much of your budget. In short, you want to make sure you’re achieving a good return on your investment.
Fortunately, there are more and more options that can provide serious capacity and deep functionality as part of HP®’s extensive
small business and home office laser printer line. It’s never been easier to find the best color laser printer at the perfect price and configuration for you.
In this article, we’ll help by exploring five of the best
HP color laser printers for home offices of every type. The list will cover a range of prices, functions, and styles thanks in part to a standout model from the
HP-Samsung laser printer family:
- HP LaserJet Pro M254dw color printer
- Samsung Xpress SL-M4530ND laser printer
- HP LaserJet Pro M203dw laser printer
- HP LaserJet Pro M281fdw color printer
- HP LaserJet Pro M148dw color printer
Before we get to the reviews of each printer, let’s first discuss the key features to keep an eye out for while you’re shopping. We’ll also explore why some users favor laser printers. Just remember that many laser printers are not rated for use in the home. Check out the emissions. If the specs state "FCC class A emissions," then that printer is only rated for commercial use, and cannot be safely used in a home office.
Advantages of laser printing
In addition to being more accurate and faster per page, it’s can also be less expensive depending on how often you print. Laser printing is simply difficult to beat when it comes to increasing print volume while sustaining quality and reducing costs.
Toner is cheaper and lasts longer than ink, so it’s a great way to save time on the bulk of your work printing. While an ink-based printer would run cartridges dry relatively quickly on a busy day, an HP LaserJet uses toner with greater efficiency to save time and keep projects on track.
With improvements in technology and design, even a home laser printer can be a best-in-class. You’ll find reliable models at affordable prices, alongside compact multifunction designs and high-capacity print powerhouses that can provide all-around efficiency at any almost volume.
The best for your home office or small business
All of the laser printer models covered in our guide can handle color output, so any other features you may want are up to you. Whether you need the best wireless color laser printer or useful administrative features like access to easy faxing, you’ll find HP home office laser printers designed to tackle any related task.
Everything here is also designed for relatively high-volume print routines. Some strike different balances between price and functionality, and others go all-out for capacity and higher print speeds.
Make sure you shop based on your priorities, whether it’s sticking to a budget or simply providing your office with the best of the best. That’s the advantage of a truly varied selection.
Do I need a single function or multifunction printer?
If you’re looking for the
best laser printer for home use, you’ll be glad to know there are reliable options available that can help you tackle myriad tasks.
Ask yourself if you need to scan and copy as well as print when you are considering what makes the best laser printer for your home. That includes considering faxing capabilities, too, which can be absolutely necessary or completely unnecessary depending on your individual needs.
It’s worth determining beforehand if you ever plan to use a fax as part of your home business before deciding on which multifunction printer you want. For some users, the
best multifunction color laser printer for home or office use will include fax functionality.
Multifunction printers may cost a bit more initially, but they more than make up for it with their features. Just imagine not needing to go to an office supply store again to make a copy, fax a document, or scan.
But if you only plan to print with your new laser printer, then you may already know that you only need a single-function device. This
type of printer is best suited for anyone who depends on a high volume of printed documents and doesn’t need any of those extras.
Whether you’re searching for a
single-function printer or something that can handle it all, continue reading to find the top HP color laser printer to meet your needs.
5 best HP color laser printers for home use
1. HP LaserJet Pro M254dw color printer
The
HP LaserJet Pro M254dw is a wireless single-function printer with great output speeds. It sets a high standard for print speeds and startup times, with first-page-out ratings as fast as 10 seconds for black and less than 12 seconds for color. It also had print speeds that can reach as high as 22 pages per minute for both black and white and color jobs.
With built-in support for
mobile printing via your smartphone or tablet and a recommended monthly page volume of up to 2,500, it can certainly open up your office’s workflow. It also provides a boost when paired with
Original HP toner cartridges with
HP JetIntelligence, and it features a generous 250-sheet input tray.
It’s a slim device as well, measuring 15.4 x 16.5 x 9.7 inches, so it can easily fit into a variety of workspaces. This can be particularly helpful if you’re looking to free up some space in your office or simply don’t have any space left to spare.
The HP LaserJet Pro M254dw is an ENERGY STAR®-certified, EPEAT® Silver device, too. That means it’ll reduce your workspace’s carbon footprint while making a minimal impact on your energy bill.
Additional Features:
- 100-sheet output bin
- 4 cartridges; 1 each black, cyan, magenta, yellow
- 2.7 inch color display
2. Samsung Xpress SL-M4530ND laser printer
The
Samsung Xpress SL-M4530ND provides efficient desktop laser printing at an accessible price point. It features easy mobile printing and quick speeds in black up to 47 ppm. It also has a respectable 15,000 recommended monthly page volume. Depending on your print volume and specific needs, that may be just what your home office needs.
For color printing, you’ll have extra confidence when it comes to image fidelity thanks to ReCP resolution technology and Smart Color Management System. These prints may take a bit longer than their black and white counterparts, but you’ll end up with smoother, better-looking images.
This Samsung printer also has a small footprint at 17 x 18.1 x 15.4 inches, making it perfect for the most restrictive office spaces. Plus, you only need to access its interior to replace supplies or perform basic upkeep, so you won’t sacrifice extra space unfolding or securing extra panels with your routine work. And even at its smaller size, it still contains a 550-sheet input tray and a 500-sheet output tray so you won't have to worry about refilling often.
This Samsung Xpress is well prepared to keep your environmental impact down to the bare minimum, too. It’s ENERGY STAR qualified. Want to cut back on your supply use with a lower priority job? The automatic duplex printing and high capacity toner will streamline toner and paper consumption.
With an affordable price tag, smooth wireless functions, and efficient energy consumption, this Samsung printer is a great enterprise-friendly option for businesses of any size.
- Automatic duplex printing
- ReCP resolution technology
- 512MB memory, standard with the option to upgrade to 2GB
3. HP LaserJet Pro M203dw laser printer
For an extremely modest price, the
HP LaserJet Pro M203dw offers a compelling argument for a print-only home office laser printer. Like other models in our list, it’s still relatively compact and low-impact, with the same ENERGY STAR certification shared by most of our entries.
It’s quick to activate and start printing with this device thanks to first-page-out rating as fast as 6.6 seconds. It also has an impressive maximum print speed of 30 ppm in black. While other entries on this list are similar in these specs, that’s still the speediest estimated output available at this price point.
This HP LaserJet printer carries over several of the best features from other entries, too. It features HP FastRes technology and HP Printer Assistant for sharp, easy to print results.
- 250- sheet input tray, 10-sheet priority tray
- HP ePrint, WiFi direct, AirPrint, Google Cloud Print capable
4. HP LaserJet Pro M281fdw color printer
The speedy and affordable
HP LaserJet Pro M281fdw is a great wireless multi-function printer. It’s perfect for home offices that need access to vibrant, high-clarity color prints, without sacrificing an efficient workflow.
It has strong first-page-out ratings with both color and black prints, too, at 10 seconds from power-up to completion for black and less than 12 seconds for color.
Its print speed estimates are equally as fast for both color and black pages, with a maximum output of 22 ppm regardless of what you’re printing. And if you’re rushing to print a lower priority job, you can count on even greater speeds when using draft settings.
Automatic duplex printing also helps save time and materials with an easy change to your print settings.
This HP LaserJet also boasts access to Original HP Toner cartridges with HP JetIntelligence. They help provide more efficient printing and higher page yields of up to 48% more than the competition.
If you’re concerned about your power consumption, this printer has a full slate of certifications including ENERGY STAR approval and an EPEAT® Silver rating.
Plus, as a
multifunction printer, it’s an all-in-one device that lets you fax, copy, and scan documents as needed.
- 256MB memory
- 2.7-inch color graphic display
5. HP LaserJet Pro M148dw color printer
With a deep suite of features, the
HP LaserJet Pro M148dw is a great multifunction print hub at a price that won’t break the bank. It has the highest possible print yield when using Original HP Toner cartridges with HP JetIntelligence in addition to super-fast automatic duplex printing.
It has great
printer paper capacity, too, with space for 250-sheets in the standard configuration and a 10-sheet priority tray.
It also boasts easy scan-to-email and
mobile printing. You can set it up in just a few simple steps and clear any office traffic jams around the printer virtually right out of the box. It has the best
wireless printing on our list, too, with the support of built-in WiFi, wireless direct, and convenient NFC touch-to-print technology.
- 2-line LCD display
- Up to 30 ppm print speed in black
- 2,000 recommended monthly page volume
In summary
Finding the right printer can often depend on knowing how much and how often you’ll be printing.
For most consumers, whether you need the extra capacity and efficiency for a hobby, new business, or a growing home office, the best color laser printer for home use needs to fit the scale of your work. Picking the right one for you is a question of what features you need most right out of the box, but also what you may need down the line.
Each of these models is a robust color laser printer designed for efficiency, precision, and scale to support you and the growth of your home business. From the best wireless color laser printers for home use to multifunction print hubs that also scan, copy, and fax, you can find what you need from HP®.
About the Author
Dwight Pavlovic is a contributing writer for HP® Tech Takes. Dwight is a music and technology writer based out of West Virginia.
Popular HP Color Laser Printers
